some months ago I had a problem where none of the cycles on my dishwasher would work except pots and pans. No other buttons would light up or function.
I lived with that for some time until the other day when the dishwasher stopped working altogether.
I spent a lot of time reading your wonderful forum, and ultimately made the decision to roll the dice and install a new thermal fuse and new electronic control board.
That didn’t solve the problem.
Now I’m trying to decide whether to try installing a new front console/key panel or just cut my losses and buy a new machine.
Here is the tech sheet, it gives the procedure for checking the control panel.
See attachment.
The following is a long shot since so many keys do not work but is probably worth trying.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
