Food freezing in main compartment and top produce drawer
Hello, I have aproblem with food freezing in the main compartment and top produce drawer in our Maytag MZD2768GE.
Hello, the temperature in the freezer compartment shows to be 10 degrees below zero. What should I check next?
Thanks,
You probably have a bad cold control AP4070269
Where would I find the cold control and how to check it?
Behind the control panel where the temperature control knob is. Make sure to route the new sensing wire exactly where the old one was. Symptoms show a bad control. Try spraying with a non-residue contact cleaner available at Radio Shack, might un-stick it.
