maytag fridge freezes all food
Refridgerator freezes food even in off position of temp control, freezer works fine.
Hi.
Adjust the air flow into the refrigerator to the minimum.
If that not going to help - replace the cold control
61005789
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=48726
Thank you. Post the results.
Simon.
Might also be a good idea to check the freezer temperature.
It should be from 0 to 5 degrees F.
