The Temperature Control Does Not Have Any Effect. Set At 46 Degrees Referigerator Temp, 0 Degrees Freezer Temp. Actual Cabinet Temp Is 32 Degrees, Crisper Temp Is 28 Degrees, Freezer Temp Is Minus 15 Degrees. Bad Temp Sensor??
Related topics
maytag fridge freezes all food | 3 | 1719 | June 27, 2012 | |
The refrigerator control has no effect. | 16 | 4080 | July 16, 2010 | |
inside of fridge temprature to cold on lowest setting. | 1 | 1533 | August 28, 2008 | |
Freezer Fine -Refridge too cold | 4 | 1061 | August 18, 2014 | |
Fridge not cooling enough, but Freezer is fine | 1 | 127 | August 19, 2019 |
