Freezer Cold,But refrig warm
Problems with Frigidaire FRS6R4E Side by Side Refrigerator. Freezer cold, but frig not blowing any cool or cold air to refrig. I checked the back for frozen lines, dust, and anything unusual. Everything looks fine. I took the plastics rail(inside refrig) off the check to see if the damper open and working. It opens when shutting off and noticed it opened for air flow. I discovered no cold air being transfer from freezer to refig. I checked the bottom inside refrig, and noticed more vent hole. No air blowing, but noticed the lines inside froze up with ice. Need help!
I HAVE A BAD COUPLING. NOT SURE HOW TO REPLACE. DO YOU REMOVE TRANSMISSION? HELP!!! MARK:confused:
Just remove the outer case of the washer, remove pump, and motor. Pry off the bad coupler and pound on the new one. Turn the tranny coupler clockwise till the spin basket just starts to turn. If hard to turn the coupler with thumb and forefinger, you have other problems. Post results.
