freezer dripping defrosting, coils defrosted still not working fan running loud
2 Days Ago Ice Cubes Stuck Together, Freezer Not Cold Enough
Defrosted The Coils Behind Panel. Turned Back On Freezer Never Got Below 25 Degrees What Next…? Fan Below Ice Maker Sounds Loud Replaced That Fan 2 Summers Ago
Here are the parts includes a wiring diagram.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=MSD2756GEB
Why did you defrost the evaporator coils?
Were they heavily iced/frosted over?
Or did you assume that a defrost problem was the most likely cause?
Is the compressor running continuously?
Is the condenser/compressor fan running?
Is the evaporator/freezer fan running?
Are the condenser coils clean? Also the vents, front and back.
