Freezer gets too warm occasionally
So as near as i can tell The freezer is getting too warm and causing the outsides of my food to thaw. However it cycles from being fine to too warm. It’s to the point where sorbet ice cream turns into an aqueous mass.
From what i’ve read this is an issue with the defrost cycle running too long, but a confirmation or correction on this finding would be helpful. Also possible solutions to the problem would be much appreciated.
Thanks for your time
Most probably your cold control (AP3084361) is sticking. Next time it stops for an abnormally long time, tap on it. If it then turns the compressor on, that would confirm it.
