The freezer is too warm in my GE Profile [FONT=Calibri][SIZE=2]PSS26NSTSS side by side.
Noticed frost on the back of the freezer, used a hair dryer to warm it, and then the evaporator fan kicked on after 5-10 minutes of defrosting, and then the refrigerator returned to normal after a bit.
It seems the evaporator fan doesn’t come on unless I defrost the rear of the freezer first. From there, it will maintain good temps for a couple days and then slowly start to warm up. [/SIZE][/FONT][SIZE=2]The refrigerator side is close to normal, even closer when the freezer is close to 0 degrees.[/SIZE]
Compressor and compressor fan are working fine, and the compressor’s radiator is cleaned as well.
Could this problem be the thermistor by the evaporator?
Thanks!
[/SIZE][/FONT]
