Kenmore (m#-25373012303) freezer is leaking down into the fresh food compartment. Checked the drain and its not clogged or frozen. There is no ice build up on or around the ice maker. And both areas apppear to be cooling normally. Thought it might be condensation from a leaking door seal but they are both in good shape also.
Any ideas would be greatly appreciated
