Freezer not Defrosting/Frig Side wWarm
My Maytag side by side is not working right. The Freezer is not defrosting, continues to Build Up Ice and then the Refrigerator is warm. We think the coil is not working but not sure.
We defrosted freezer 3 days ago and tonight the frig side is Warm Again:confused:
Please help me to know what to do next???
MSD 2554ARW Serial # 11696092UW MayTag Side by Side
Here is your parts breakdown.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=MSD2554ARW
Sounds like a defrost problem.
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle by turning the defrost timer cam (Item 13 in Section 2) till the fans and compressor turn off.
The cam only rotates in one direction and there is usually a hole in the cover to let you turn it.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it’s rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Unplug the heater/defrost thermostat assembly ( Item 12 in Section 4) and measure across it.
Usually around 20 ohms or so.
Note: The defrost thermostat opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
  1. Always remove power from the machine otherwise you could blow your meter.
  2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
  3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
If yes.
If not on.
Unplug the unit.
Thank you DENMAN! It was the Defrost Timer and the Element. My husband repaced both items after checking as you outlined and The Old Frig is BACK TO COLD!
Happy Holidays
You are welcome and Happy Holidays to you and yours.
The good news is you are up and running.
The bad news is Holiday leftovers are going to last longer.
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
