Fresh food side getting to cold.
The fresh food side is freezing water regardless of the temp setting. After searching through the forums I thought it was the damper, but it is not. The damper opens and closes. So I believe, and correct me if i’m wrong but it is the temp control unit. It seems as if it is no longer reading the temperature, instead it opens the damper and runs the fan regardless of the temp in the fresh food side. Is there any way to test it? If so how might I do so?
Thanks in advance
