freshfood side to warm/ coils frosted
The Freshfood Section Is To Warm Unless It Is Turn All The Way Up To Coldest Temp , The Freezer Side Works Ok But It Also Has To Be Turned Up . There Is Frost On The Coils In Back Of The Freeer Section And Back Panel Frostes Up ., They Tell Me This Model Has No Defrost Timer , Please Help.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=ED5VHEXVQOO
You are correct you do not have a defrost timer but you have an adaptive defrost control board (Item 6 in Section 11) which basically does the same thing.
From your comments it sounds like you feel you have a defrost problem.
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle (see the tech sheet). The fans and compressor turn off.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it’s rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element (Item 33 in Section 9) from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat (could not find it in the parts but it will be clipped to the evaporator coils ) and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost control board is toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
  1. Always remove power from the machine otherwise you could blow your meter.
  2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
  3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
