Fridge and freezer stopped cooling suddenly
Refrigeator stopped working a month ago. Replaced overload relay. Worked for about two weeks. Now not wokring again. All fans work, but know cooling. Tried another overload relay. Could it be the motherboard??
Most probably the motherboard. Pull it out and check for bad solder connections in the back by the power relay.
