Cleaned coils 2-3 weeks ago when it first stopped cooling…very dirty…never were cleaned before. Plugged it back in after being off over night and started cooling again right away. Now 3 weeks later fridge and freezer stopped cooling again. Just unplugged it again over night and it is working again. Any ideas on where to start to look for this problem.
I would pull he motherboard out behind the fridg and look for bad solder joints in the back around the power relay. If ok, I would replace the board and the refigerator thermisters. Board # AP4436216, thermisters(a white, thin plastic part) AP3185407
Is the Evaporator Coil in the back of the freezer freezing up? (does it have about a 1/2 inch of frost and ice?) This may be a problem with your refrigerators Defrost Cycle and would be far less expensive to repair!
Pull the 3 pin power connector(gray plug) off the motherboard, notice which pins on the connector mate with the pc board line and def. pins. Stick a jumper between these pins and see if it now defrosts. If so, you have a bad motherboard. If not, you probably have a blown defrost heater.
