The fridge is cooling the items just fine but the fan is always running. It seems when I notice the fridge is always running. I have cleaned the coils and backside. I don’t want to call a repair person b/c the fridge is from 1991. What would cause this to happen?
Measure the back wall freezer temperature and post.
temp on back of freezer is 2deg F.
No, that is part of the defrost system. the part I listed above is the control.
Nat
When it’s pluged in moter runs but it won’t get cool.
— Begin quote from Walleye cooter;118410
I have the same fridge in the garage for a wine cooler. When I first bought it I thought it was broke but I turned the dial(in the back by the condenser) all the way up and now it works ok. Not COLD, but everything is COOL. I’ve heard HAIER is no good.
By the way, the freezer in it will never work… get used to it. It just freezes when its running and then melts water all over off the freezer.
— Begin quote from ChrisMNS.Ut;118448
You may have a door seal problem or thermostat .
As regards to refrigerator working continously coukd be out of FREON ,arestriction or compressor not pumping:cool:
Haier Wine Refergerator Does Not Cool
