Fridgidaire Wall Oven not heating
The bake element on my wall oven burned out. I replaced the element and the oven does not heat up. The broiler element does not heat up either. I have checked the safety thermostatic for continuity and it s good. I assume the control board is bad. Is there a way to check this before i order a $200 part? Would the element burning out short out the card?
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=GLEB30S9FSA
Here is a service manual which I think is close to yours
http://frigidaireservicetips.com/pdfs/481_18.pdf
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
I am not sure how the safety thermostat works on this unit so I would remove power from the oven, unplug one side of the thermostat and check it with a meter should be 0 ohms.
There does not look to be any diagnostics.
The Frigidaire site seems to be down so I cannot get you a tech sheet with a confirmed wiring diagram for this unit.
[COLOR="Blue"]
Would the element burning out short out the card?[/COLOR]
Does not really short it out but often when an element burns out it creates a voltage spike and that can blow electronic parts on the control board.
Thanks. I checked all the voltages and they are correct. The resistance on the thermostat is 0 ohms.
I disconnected the l2 out of the card and checked the voltage with the oven in bake. The l2 to neutral was zero. I would have thought this should be 120v.
Yes if the board was working correctly you should see voltage.
Since there is a L2 in and a L2 out there may be a relay on the board that closes on this line.
And if the relays for the bake or broil are not closing you would see 0 volts from L2 out to Neutral.
Looks like i’ll be buying a new board. hope this works.
thanks
Got the board in today. Hooked it up and the oven works. $300 to replace the burner and the control board on a 4 year old oven that isn’t used to often. Doesn’t say too much about frigidaire’s quality.
Thanks to ApplancePartsPro for getting me the parts quick.
