Oven will not heat
Hey… I have a fridgidaire wall oven that will not heat. It started out taking longer to get hot to now no heat at all. This is a single unit. I’m not sure of the model number but the control model number is 318003902. You can still hear the control making the click sound it makes when you turn on the oven but no heat from either the top or bottom element. Does this sound like a control board problem ?
You will need a model number tro be able to find the parts.
http://www.appliancepartspros.com/modelnumber_locator.aspx
Could be the control board/clock/timer but there are also other possible causes.
First you have to check the power. The elements require the full 240 volts but the clock and oven light only need half the line (120 volts).
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
Does the oven say it is ready or does it stay in preheat?
If it says it is ready then it could be an oven sensor problem.
Also some units have a thermal cutoff in the element circuit.
I would need a model number so I can search for a wiring diagram of this uniot.
