oven will not heat up
this is a wall oven .when i turn it on it does not heat up at all upper or lower elements do not get hot.this happend all at once… what could this be?or what part do i need?
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=fes367abg
Here is the tech sheet
http://manuals.frigidaire.com/prodinfo_pdf/Lassomption/318045067.pdf
Something is wrong the model number comes up as a slide in range not just an oven.
First thing you want to do is check the power to the unit.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
If the power is good then it is probably the control board though some units have a thermal cutout that can cause problems.
