My oven will not heat at all. I read on here it is probably the EOC. I just wanted to try and verify before I bought the part and see if others have had this problem.
Thanks.
Thanks.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=PLEB30S9FCD
Here is the wiring diagram
http://manuals.frigidaire.com/prodinfo_pdf/Lassomption/318046251.pdf
It could be a number of things.
First I would check the power.
The bake and broil elements require the full 240 volts. Looks like everything else will run off of half the line (120 volts).
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
Does the unit stay in preheat or does it show that it is ready.
if it shows that it is ready then it could be the oven sensor.
It should be about 100 ohms at room temperature.
It could be that the thermal circuit breaker (item 119 in the Body Parts section) has opened. if you click on it’s picture or description a new page will open with more info. You will see a red area on the back, it will pop out when the breaker opens. Push it in to reset it.
If it is open then you will want to check the oven temperature with an oven thermometer to be sure that it is not over heating and popping the breaker.
Also check that the cooling fan is operating correctly.
If the above are OK then odds are that it is the EOC.
