Frididaire top loader tub seal
Hi.When installing the new lower tub seal,I pushed it down,put the top seal on top of the first seal,put the inner basket on and there was a pretty big gap between where the indentation on the shaft for the trunion block goes and the seating of the tub.Its like the seals werent think enough.So I took took off the tub,unsprung the lower seal and gently layed the tub on so the truinion block and bolts lined up with the indentation on the shaft.Now It leaks a drop of water.The kit i bought came with a felt washer (wick),which i didnt have on my old machine,water slinger,retaining snap ring(which i didnt have on the old washing machine,and space washers(which i didnt have on my old machine.All that I had on my old machine was the bottom and top seal.What could be the problem?..hope this made sense.Thanks
