Frig temp 56, actual 33
I have replaced the Main Control board, the defrost thermistor and the Thermostat in the frig section hidden behind coils near the bottom. Temperature and readings from freezer side are fine, but too cold in fridge. THis does not match the temperature reading on display. Not much change in performance when I replaced thermostat (model Wr55X10025). What next?
Is it possible that I misaligned one of 6 plugs on control board install, or I have a bad plug?
HELP!
