Hey guys, i’ve been reading a lot on this forum and tried everything suggested to fix my dryer.
I have a Frigidaire affinity and unfortunatly i can’t seem to have any source of heat.
I’ve followed a few videos on how to test and see what was the issues and replaced the thermistor. The dryer stopped giving me error codes and stopped flasing after 2 mins and does full cycle to dryer my laundry.
Unfortnatly I wasn’t getting any heat so i replaced the thermal fuse and the Safety Thermostat even if they had pass the test (resistance).
I’ve also tester my heater element (continuity is fine and i’ve also tested the resistance 12.9 - 13 ohm).
I’ve run out of luck and deviced to ask for help.
P.S checker that return hose isnt clogged and cleaned all the lint inside my dryer.
Fan is running fine also juste cold air even if i select maximum tempurature.
It’s an electric dryer
