Frigidaire Affinity Washing Machine - Leaking only sometimes
Hi - I have a Frigidaire Affinity washing machine, front loading - that leaks only sometimes. It seems to drain fine, and run fines. Just sometimes, I get a puddle on my floor when using it. Any ideas?
Thanks!
Omf_24, if the model could be provided, this would allow the most accurate information to be presented. Generally speaking, the point of origin of a leak would need to be checked for. If the small puddle is occurring at the front, the front panel would need to be checked for any water residue streaks that may indicate the door was leaking. This is often caused by fibers on the front glass creating a breach in the door seal.
