frigidaire, code, f10
Hello i am getting an F10 ode on my range…Does anyone have any clue to what needs to be fized??
bvlover2000@yahoo.com
Jackie
Hi Jackie,
"F10" error code means "Runaway temperature". In which mode (cooking, cleaning or time) of the oven does it appear?
Most likely the problem is a bad control board (aka a clock) which has to be replaced together with the overlay.
Here are the break down diagrams for the Frigidaire range http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=1228390&&model_id=5147953
Why would I need both the e.o.c and the overlay?
— Begin quote from Gene;52375
Do they have to be bought togather? Also why is that?
One of the relays on the control board is stuck closed.
The overlay is attached to the control board and it is almost impossible to remove it without damage to it. It has been recommended by the manufacturer to replace them together.
