Electric oven F-10 error
When i would turn oven on to bake sometime would switch which burner works. It would heat it up to the temperature with one heater and than would pup a code F-10 and would shut it off. I did not see anywhere on this blog F-10 code. Please help.
The "F10" error code means "Runaway temperature". Most likely the problem is a bad Electronic Oven Control (aka a clock/timer). It has to be replaced together with the overlay because it’s glued to the clock.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=898926&&model_id=5159107
