While baking, heard a loud noise from another room. When I came back, the control panel was blank and the breaker had flipped. When I reset the breaker, the range top works, but the control panel is blank. The elements look fine. Electric oven. Ideas?
Hi.
Check if you are getting 240VAC to the clock L1 - L2in.
If the correct voltage is present - replace the clock
You may need the overlay too.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5147932
Post the results.
Simon.
