My Frigidaire PLES389CCB Frigidaire/electric Range oven stopped working. the entire front panel went out (all touch controls electronic timer and oven controls) the upper range is working.(electric burners).
I replace the clock timer contol (front panel) but that did not change anything. I am now 400.00 bucks in the hole and lost. Seems like something else is causing the outage.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=PLES389CCB
Here is the wiring diagram
http://manuals.frigidaire.com/prodinfo_pdf/Lassomption/318045064.pdf
Does the stove top element on lights work (not the hot surface)?
The reason I ask is that they use L1 to Neutral power (120 volts) and so does the control board.
If they do not work.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
