My dishwasher stops about mid cycle. If I manually advance the timer, it will finish the cycle. However, the drying cycle seems to finish faster than normal and it doesn’t get the dishes dry.
I would check the thermostat (#29 on the [B]diagram[/B]) and the heating element for continuity.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=234228&&model_id=109151
Thanks Gene. I’ll check them out and let you know.
Bob
I checked the element and got 13ohms. Isn’t that fairly normal?
The thermostat reads just over 1k ohm. Does this mean it’s good or bad?
Thanks,
Bob
I spoke too soon. I can’t find the thermostat on the diagram. The one I did find in the parts list, had a different part number than the one you gave me. I ohmed out a switch in the control panel. Where is the thermostat?
I found the thermostat. It is open. I’ll order a new one.
Keep us posted.
