Help please… My less than 2 year old dishwasher won’t complete a cycle. It won’t complete Normal or Light Wash. Will complete a RINSE cycle. What’s the deal? Thanks for your help… I’m just a girl with a bad Dishwasher and I need your help!![]()
Somebody has got to know the answer???
Susanna,
Most likely the problem is a bad heating element (#1 on the [B]diagram or a bad high limit thermostat (#29 on the [URL="http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5158903&diagram_id=1266974)).
You have to have an Ohmmeter to check both parts for continuity to find out which of them is bad.
If they both are good, then the problem is a bad wires or a bad control board.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5158903
Thanks bunches Gene!
You are welcome Susanna. Keep us posted.
Is there a video that shows how to test the heating element using an ohm meter?
