frigidaire door won't close properly
Our refrigerator door won’t close on it’s own if not pushed shut. At one time it would make a clicking sound and drop when opened but that has stopped. I have seen forums say a door cam or a hinge but I’m not sure exactly what parts I need. Thank you!
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=FRS26LF8CB0
The hinge cam looks like it is Item 22 in Section 1
The door cam looks like it is Item 22 in Section 7
Normally you can see if they are broken.
My husband went to take the door off to check to see if the part was broken, and the screw on the top of the fridge seems to be stripped. Could that be the reason the door isn’t closing. Is it possible I need a different part? Thank you so much.
Sorry but without actually being there I cannot say.
