Frigidaire dual fuel range
The digital display has quit working. Nothing on it lights up and the buttons won’t do anything. Even the oven light will not come on but the ignition still works. I took out the circuit board and checked for voltage at L1 and L2 both are at 120v and the neutral circuit N checks good so I figured the board was bad. I replaced the circuit board and still have the same problem. Any ideas?
David
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=PLCS389DCB
Here is the wiring diagram
http://manuals.frigidaire.com/prodinfo_pdf/Lassomption/318045091.pdf
Did you check L1 to L2 for 240 volts.
Often if you are checking for L1 and L2 using Neutral you will see the 120 volts on both sides but this is just from one side and it is feeding back through components and so is confusing.
Only way to properly check is to look for the 240 volts OR unplug the stove and check it at the plug.
I measured at the circuit board 120volts on L1 and L2 to neutral. At the plug I measured the same.
David
Power looks OK.
I would try disconnecting the keypad to see if the control board will light up.
This is a long shot.
Only other thing I can think of is that you received a bad control board.
I tired unplugging the switch controls and same results: nothing lights up. What are the odds of 2 circuit boards doing the same thing? Is this a common failure with this model?
David
Odds are slim but it does happen.
It is all I can think of since everything else looks OK.
[COLOR="Blue"]
Is this a common failure with this model?[/COLOR]
I cannot say.
I did do a search on this site and on ApplianceJunk and could not find a problem the same as yours.
Thanks for the help. It turned out the new board was defective. Plugged new board in and everything lit up.
David
Glad to hear you have it up and running.
Defective replacement parts does not happen often but when it does it sure can be a pain and circuit boards are the worst as there is no way to check them before you install them.
Should be a 40 amp breaker with number 8 wire.
Here is the install sheet
You may also want to keep a copy of the wiring diagram.
http://manuals.frigidaire.com/prodinfo_pdf/Lassomption/318201661.pdf
