Frigidaire electric - overheating and clicking
Recently my dryer started making a clicking noise, similar to when the button of a pair of jeans rattles around in the drum. Problem was, it was only sheets in there. I thought I smelled something, and the clicking was getting more frequent, so I pulled the dryer out from the wall. The top portion of the back of the unit is discolored and was too hot to touch - especially for something that says it has a 0 clearance on the back side.
My first thought was the lint trap or exhaust tube, so I checked both. The exhaust runs right through the wall to the outside, so that’s easy to check. The lint trap was good, so I pulled the front off the unit and found a rather large piece of flexible foam in the blower cage. I removed that and some built up lint and figured that would have fixed the problem. Got it all put back together, and the thing is still overheating (and putting out a LOT of air at the vent outside). I put my meat thermometer (all I had available) up against the back of the unit after about 5 minutes of running, and it hit 220 degrees. The clicking is definitely a click rather than a rattle - like a relay switching on and off. It’s randomly timed.
There are 6 screws at the back of the drum, and I’m guessing I have to remove those to get to the heating element. I wasn’t sure if the inner or outer ones would do the trick, and I could only get one of the six to turn anyway on my first attempt. Any thoughts?
Picture of discoloration attached. Somehow the drywall hasn’t yet been scorched.
Thanks!
No, once you have the front panel removed, remove the belt and lift the drum off the rear bearing then pull the drum out.
Here’s the breakdown
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=109415
Nat
