Frigidaire front loader
I have a front load frigidaire washing machine that does not go through the spin cycle. I am not sure what I need to do to repair the washing machine.
Pull the front kick panel under the door and remove the service package. It will have diagnostics for this but you will need a meter. Most common problems are a bad door switch, or a bad speed control board. Spin the spin basket, if you feal/hear bad bearings, you speed control board probably blew out from the increased drag on the motor. Post results.
Thanks, I will give that a try.
