My washer runs fine and washes fine until the final spin. The spin cycle starts, but when the timer hits 6 minutes time remaining, the machine cuts off and the cycle end signal sounds. The clothes are still very wet. We have replaced the speed/motor control board per a thread on this site. Same thing. Any suggestions?
— Begin quote from LisaCWilliams;729312
The model number is GLTF2940FS2
— Begin quote from LisaCWilliams;729315
I have also read that I can do a diagnostic test and if the machines spins in the test, the door latch assembly may be bad. Will the machine spin in diagnotic if the drain pump is bad?
