Frigidaire Front Water Leak
Hello,
During rinse or water fill-up cycles, water leaks from the front of the washer at the 6 o’clock position. There is a small crack on the bellows kit which I have managed to repair but water still leaks out. When looking at it closely, I noticed that water flows from the top of the bellows kit (12 o’clock) position straight down to the glass door and then leaks out. Do I need to replace my bellows kit? If so, do I just need the kit or any additional parts.
Thanks for the advice.
You can find the complete instructions in the Service Manual.
Here are the break down diagrams for the Frigidaire washer http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=1261557&&model_id=5155803
