This washer is leaking rinse water from the lowest bolt securing the front and rear outer tub halves. A local repair tech advised over the phone that parts and labor would exceed replacement cost. The bolt in the area of the drip is not loose. Is an attempt at replacing the O-ring between the tub sections advisable?
Related topics
Kenmore [Frigidaire] Leaking from outer tub seal | 1 | 3638 | February 10, 2009 | |
leaking front loader door /drum seal | 1 | 2331 | December 23, 2008 | |
Kenmore front-load washer leakage | 2 | 1449 | April 23, 2012 | |
leaking front loader | 0 | 1121 | April 1, 2009 | |
Leak in Tub of Front Load Waser | 0 | 1939 | December 21, 2007 |
