The washer has stop operating, The lights on the control panel flash on and off, Beep in no particular order. I think the control board is out but I am wondering if there are things I can do to verify that before buying a new one?
Remove the bottom panel and look for an yellow envelope with the tech sheets. Perform the troubleshooting as described there.
Here are the break down diagrams and parts list for the Frigidaire washer http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=1305327&&model_id=5155783
