I first noticed the broiler in my bottom oven wouldn’t heat and my baking pre-heat was taking much longer than the top oven. Now neither function will work. At first, I figured it was just the broiling element that needed replacing but is it common for them both to go out almost at the same time? Is there something else that could be wrong? I don’t want to go buy two new elements if it’s likely something else.
Any ideas?
