frigidaire microwave not working
microwave stopped working … timer counts down … light on… turntable does not turn or food heat
sometimes now when pushing on the door starts working for second or two
removed the control panel to see if problem with door latch
it appeared that the lower door switch came loose i snapped it back in place
when I went to put the control panel back to see if switch was the problem i noticed that two wires came unplugged
one is white connector and the other is yellow they came unplugged from the two black boxes located right next to each other
can someone please help determine which one goes where? Thanks
