Frigidaire range won't bake
New user.
Wife’s Frigidaire LGEF3033KWE refuses to bake. I checked and unit is receiving full 240VAC. Bake element shows 16.3 ohms resistance. Before I order a control board, is there anything else I should look at? I should point out that when we set to preheat, I can hear clicks, and the display shows the preheat temp, and the tiny leds light.
We’ve had it for 6 years with no problems. Thanks in advance.:frowning:
For some reason these convection ovens are hard on control boards. Changed out about 6 in the past year or so. Look closely on back of board where plug on connections are. If you see an area on board that looks brown or discolored there’s a good chance that relay on board that sends power to bake element is bad. Relay on board will still click and display lights will still come on but contacts are scorched in relay. You need board #
316557236. Should be able to get one for around $85.00.
