I have a 22 month old Frigidaire range model FGGH3047VFB that the oven has stopped working. The oven stopped working suddenly and had up to this point worked as it should. The range burners and broiler are working fine. The igniter does not glow at all. I have tested the igniter for continuity and it tests good. I then tested for voltage and amperage going to the igniter and measured 13.5 volts and 0 amps. I believe my problem is the control board however would like some guidance before I purchase a new one.
I would check the two wires that go to the gas valve and then the igniter, right at the connector on the board. You should have 120 volts there and at the igniter. If not, it might be your board.
Well after replacing the control board the igniter still does not operate. To recap, removed and tested the igniter for continuity, it was good. Tested the leads that go to igniter and got 0 amps and 13.5 volts when I pressed the BAKE button on the control panel. Replaced control panel and still no oven function. Broiler works and stove top burners work, oven, self cleaning, convection oven all do not work. Igniter does not glow at all. Is there something between the control panel and igniter that could be restricting the amps/voltage and preventing the igniter to function? Thanks.
I have the same model and am having the same issue with my gas stove. Where you able to find a answer and get your fixed?
