Frigidaire Oven and Broiler Not operating
Ok first post, and I would appreciate any input. I have a Frigidaire Freestanding range that is about 10 years old. This morning the oven and broiler would not light. THe range burners do function. I have checked the ignitors and they do not glow or get warm when I select the function on the panel. No current is measurable at the connector to the ignitor. The EOC has power to it and displays clock function. 130 V is measurable between L1 and N. When measuring current at L1 and 1 (Bake) or 2 (Broil), none is found. (Door interlock is held in) I can hear an audible click (relay?) when the bake or broil function is selected. But still no current. I believe this to be the EOC. Given the age would it be wise to replace or should I just start with a new one?
Thanks.
Hi.
According the info you provided it’s a bad control board. Most likely you will need an overlay too. For both of them you are looking about $200.
The rest is up to you.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=111893
It’s not that many things to go bad (possibly the ignitors).
Thank you.
Simon.
