Frigidaire Range...no bake or broil
After working earlier in the day, neither the bake or broil elements now work. I tested both elements, each showing resistance of about 20 ohms with no leak between inner and outer parts of the element. Checked temperture sensor, it looks good at about 1K ohms. Tested voltage at BK and BRL tabs in EOC, both 120V to common. L2 IN shows 240V to each BK and BRL. However L2 OUT shows 0V to BK and BRL. It’s like a relay for L2 is not closing. When pressing button to bake, both bake light and preheat lights come on and hear a click, but no element heat from either the bake or broil element. Cooktop works fine, lights work. Convection fan works as well. Been a little hesitant to put into cleaning mode just in case the door locks shut permananently :slight_smile: I’ve disconnected all connectors from EOC, hoping for a relay reset, no luck. No error codes appearing. I’m guessing bad EOC, but is there anything else I missed? I’m not an electrical guy, so don’t know if there’s a trick to resetting relays.
Thanks for any help!
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=FEFL78CBA
[COLOR=Blue]
I’m guessing bad EOC, but is there anything else I missed?[/COLOR]
I do not think you missed anything
For a non-electrical guy you have done one helluva good job at diagnosing this. Sounds like the relay is closing but it’s contacts are shot.
