Frigidaire range oven & broiler not working
The oven & broiler on our Frigidaire model FEF326FSB range quit working after tripping breaker twice. Clock and range top still work. There is continuity and correct resistance on both elements. There is continuity and resistance on temperature sensor, which I removed and heated up to see if resistance increased which it did. When broiler only is turned on, there is voltage at the bake terminal on the EOC. Also at L2 in & out. Is this proper or is the EOC bad? I never got an error code on the display which it seems that I should have.
Here are the parts
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=FEF326FSB
Could not find a diagram for a FSB so the following tech sheet is for a FSA
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316255302.pdf
Sounds like you have had a dead short someplace in the unit. Check for tell tale arc/weld mark or burned wires in the unit and on the board (especially the relays and their solder joints)
[COLOR="Blue"]
When broiler only is turned on, there is voltage at the bake terminal on the EOC.[/COLOR]
I am missing something here.
If you have 240 volts from the bake terminal to L2 out, the bake element should heat.
It does sound like your board has blown a relay.
Thanks for the help, I’ll replace the EOC.
