Frigidaire Range
[SIZE=5]my range was preheating the oven when a loud popping sound came from the rear and then the [/SIZE]
[SIZE=5]control panel started beaping.The oven will not work on the top or bottom burner. I have removed the rear cover and dont see anything that appears to be the problem.The top burners and the controls for the clock and oven seems to be working ok ,I did find when I removed the back panel at the top that the plug that plugs to the control panel was barley connected.[/SIZE]
