I have a Frigidaire (make by Electrolux) stacked washer/dryer unit.
It has occasional squeal or squeek when starting and was told rear drum bearing as likely bad. I have the bearing kit and am interested in knowing how to go about replacing the bearing.
I’m assuming the somehow the front cover comes off the dryer unit and I then remove the drum from the front. With the drum out then accessing the bearing is possible.
Or… will I need access from the rear of the dryer to do this?
