Frigidaire Refrigerator
Not cooling none of it Its a side by side and never side is cooling.Just happen all at once
Refrigerator not cooling not even the freezer happen all at once
Is the compressor motor running.
Check to see if the condenser fan at the back underneath near the compressor is running.
Are the condenser coils near there warm or room temp
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Yes the fan is running and I also put another fan back there to help see if it will work.Cant get the air to goo over to the refrigerator side for some reason but it still dont tell me why the freezer not working.Just check everything seem to be working .
Yes There Is Some Freezing Down On The Bottom Part Of The Freezer.does This Mean Low On Freon Or What
The Coil In The Freezer Behind The Panel Is All Frooze Up And The Lines Too
You can defrost it with a hairdryer to get by till you fix it.
How to check stuff
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control
Your model number doesn’t match any I have access to to find if you have a timer or control. http://www.appliancepartspros.com/modelnumber_locator.aspx
My ref. keeps freezing up and wont get cold.I have to keep taking hairdryer and unfreezing it so it will work I cant find the defost timer to check it My model is FRS23W3AWA and this is the model its right inside the door and says model number the serial number isLA34619140.I dont know what to do to find the switch for I dont know what it looks like.
Our Whirlpool LSL9345E washer drains as it fills. It seems to fill part way,then doesn’t fill any more because it’s draining at the same time. If I fill the tub the rest of the way with water, then it stops draining and proceeds to wash or spin, depending on where it is in the cycle. I was thinking it might be the timer because once the tub fills, the draining stops. Anyone out there have the same problem? Thanks, Rich
