Hi,
My wife did an oven self cleaning. After that 3 out of 5 stove tops’ igniters stop working. Any suggestion?
Thanks,
Philip C.
Hi,
Thanks,
Philip C.
Hi.
When you turn on any of the burners does all of the ignitors spark? If you turn on one of the non sparking burner would the others spark?
Post the results.
Simon.
No. None of the conditions happened. The two stove tops on the left hand side worked properly. The middle one and the other two on the right hand side do not. They don’t seem to affect each other in any way.
Philip
Hi.
Most likely you should replace the spark module.
Here are the breakdown diagrams and http://www.appliancepartspros.com/burner-parts-for-frigidaire-fpgf3685lsa.html
Post the results.
Simon.
Ok. thanks.
Philip
You are welcome.
Simon.
