I Have A Frigidaire Gallery Top Load Washer Model Fws645ghs0 That Does Not Spin Up To Speed On The Final Spin Cycle. Water Drains Out Properly. I Have Replaced The Belt But It Didn’t Help. Doesn’t Seem To Matter If It Is A Small Load Or A Large Load, Although It Happens Regularly With Small Loads, No Matter How Many Times I Rebalance The Load. Any Suggestions???
Sorry for the delay in getting back to you. Washer spins after wash cycle but I’m not sure if it is supposed to go as fast as the final spin. Everything seems to be working fine except for the fact that the clothes are still wet when machine stops. Water drains OK, spin is not as fast as it should be. Anything else that you can think of would be appreciated.
Operate it with the front cover off, and check the drain pump and internal drain hoses for any obstruction. I have had several partial obstructions near the tub with these models.
The dryer runs but does not put off any heat someone told me the check an element where do I do that an is there a element
washer gets power to water valve but will not fill and has a new valve
If power is getting to the valve assembly then either the valve assembly is broken or there is no water coming in from the hoses. Assuming you have checked the hoses, what I do in this situation is use a test cord (make one out of two alligator clips on one end and keep the plug end) and get a power strip. Hook a hose up to one of the inlet places and attach the alligator to each one of the terminals on the inlet valve you have hooked the hose to.
Plug the test cord into a power strip that is turned off. Set the valve assembly in the laundry hose in a way that water will not get on the connections at the valve, turn the water on and then very briefly flip the power strip one. If water comes out everything is working, if not the valve assembly is not opening.
Be careful not to short out the connection with the water.
notice
a problem has been detected with this unit
