Frigidaire top-loading washer agitates but doesn't spin
I have a top-loading frigidaire washer that is agitating but not spinning. There is also a burning smell during the spin cycle. The water is draining fine. I’ve replaced the tub bearing and the belt, and also tested the door switch, but the problem still persists.
Are the only other options replacing the motor or transmission?
